discs def
but depends on the calipers m8
if u have the same calipers as the 16v 6n or gti then u just need carriers n g60 discs
sure someone will know more
hiya
i got a mk4 8v, which i changed into a 16V, so swapped the front hubs to 256mm ones, then got corrado g60 calipers and carriers, giving 280mm, they work a treat!
as for the rear, get a rear beam off a mk5 gti, disc conversion!
sorted!
obviously swap discs, pads etc
