[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Help... Turn Key Nothing Happens - UK-POLOS.NET - THE VW Polo Forum
Just wondering if anyone had experienced this.... Got in the car this morning and opened the door, ffuel pump made the noise that it makes and then put key into ignition and the fuel pump made the noise again (nothing unusuall there) then i turned the ignition so all the lights come on and waited for the lights to go out and then tried to start the car and... NOTHING... not even a sound what so ever... Any ideas????
Thats what i cant understand, It starts first time, everytime and has never let me down untill now...So i was thinking imobiliser or somone said about ignition failing
When you try and start the car, do the blowers cut out? That's what happened to mine when I experienced the same symptoms. I needed a new ignition switch to fix the problem, its been right as rain ever since!
Si... Just tried what you said.. turned the blowers on and then tried to start it and they do go off!!! the radio stays on though... does this mean it could possibly be an ignition switch then... if so whats the damage £ ? can anyone that has a working gti try the blower theory to see if theirs turns off ?
Similar thing happened to my mate. He got home from work, went in the house, came back to his car, tried to start it and nothing. Got it to VW and it was the car not recognising the key. Had to have new ignition something or other. Cost around £100ish i think.
yeah i had this problem 3 years ago it could be a dodgy ignition barrel take the cowling off and waggle the wires i did this and had no trouble since. but the immobiliser was working cos i bump started it
