Air blowing through pipe on bottom of engine to air box
polowebasto
Post by polowebasto »
The car is now running a treat with the top off the air box and this reveiles like mercky colour smoke or air what could this be and the cure please. I like the mk1 polo and all the other vw. I would post you a pic but i carnt work the photo web site thing i do not understand it. Thankyou David.
omicron
Post by omicron »
Just vapour from the head. Don't worry unless there's a lot of it. Though without knowing the full story of your problem, it's hard to say.
steveo3002
Post by steveo3002 »
from the bottom of the engine? that sounds like the block breather , prob puffing out a few fumes due to to wear
i got some rubber hose and a elbow and routed it to free air under the car, that way the carb breathes clean fresh air , dont forget to block off the hole in the filter if you do that
polowebasto
Breather re routed
i have re routed the breather down to where the fuel lines come up from underneanth. This dose not mean valve seals or piston rings then.
i brought the car for £30 a year or two ago and have spent £40 on plugs and servicing it also outer cv boots and anti rool bar bushes. i have welded the o/s/r bottom valence a bit on the o/s sill and the rear of the spare wheel well. Ii have to do some small spots of rust on the bottom of the windscreen After the mot. i also mended the fuel tank with some resin from halfords. the car has a full size slide back webasto sunroof is this rare or just an after market fitment or standard on some trim or modles. Thanks for the help. David.
steveo3002
it probably is a bit worn , but unless its hoofing out loads of smoke i wouldnt worry
webasto was prob a accesory fitted when new
