Where is pollen filter?
richl123
Post by richl123 »
Hi, can someone tell me/show me where the the pollen is located on a Mk7?
Thanks.
yorks GT TDI
Sponsor
Post by yorks GT TDI »
under the glove box
richl123
Post by richl123 »
yorks GT TDI wrote:under the glove box
Sorry can't see anything, what am I looking for?
Buzby
Sponsor
Post by Buzby »
Working in the passenger side footwell, You need to take off the cover tray under the dash (2 torx screws then pull towards you and down). You'll see on the RH side a cover about 50mm wide with two clips at either end, these clips need to be pushed towards the middle of the cover.
The cover then can be pulled away (downwards) exposing the pollen filter. If you then pull the filter it will come out of the slot. Then replace the filter, with a white paper one (pollen), or a grey carbon/paper (pollen/odour) filter.
Be prepared for dry leaves/seeds etc to fall into the footwell.
HTH :wink:
richl123
Post by richl123 »
Thanks, I assume the facelifted polo is the same as your one?
Do you know if VW sell a combined pollen and activated carbon filter?
Buzby wrote:Working in the passenger side footwell, You need to take off the cover tray under the dash (2 torx screws then pull towards you and down). You'll see on the RH side a cover about 50mm wide with two clips at either end, these clips need to be pushed towards the middle of the cover.
HTH :wink:
Buzby
Sponsor
Post by Buzby »
Your facelifted polo should be the same.. I don't know if vw do a carbon filter. I've got my pollen filters from Euro Car Parts http://www.eurocarparts.com along with the air, fuel, and oil filters once a year, as they do OE spec parts.
HTH :)
