What manifold?
Kam Racing
What manifold?
I'm gonna be looking to mod my Polo 6N2 Gti once i've finished building my peugeot 205 trackcar.. what manifold do you think i should go for? I've heard the supersprint one gave the best gains but is no longer available.. Are there any others that are as good?
On the two branch bend, heat needs to be applied so you can bend it slightly out of the way of the cross member.
It also needs to be pulled slightly to one side, so it clears the sump.
Ideally, a stainless exhaust flexi should be fitted, as the engine vibrations could crack the stainless.
Also, as the steel is very thin, its quite tapping when cold.
If you get some exhaust heat wrap and wrap all the pipework this pretty much solves it.
Re: What manifold?
The SuperSprint manifold is still availale. I rung SuperSprint UK yesterday.Kam Racing wrote: I've heard the supersprint one gave the best gains but is no longer available..
olop_chris
- Sponsor
Kam Racing
