9n 195/45/16
9n 195/45/16
Hi guys. Want to get some 16's. Was just wondering what the perfect tyre would be. Seen a set of 195/45/16, would these be ok to go stright on my 9N or do you suggest any different? Thanks
carmadaaron
Re: 9n 195/45/16
yes they are fine!shakt1 wrote:Hi guys. Want to get some 16's. Was just wondering what the perfect tyre would be. Seen a set of 195/45/16, would these be ok to go stright on my 9N or do you suggest any different? Thanks
M7
it all depends on the width of the rim. there are suitable tyres for certain rims depending on what width they are.
if you want a good fitting tyre for a 7" rim, i'd suggest a 195/45
if you want a stretch on the tyre if you have an 8 or 9" rim then you start to down size abit. i've seen 195/45s on 9" rims, which create a mad stretch.
just all depends what look you want and what rim you have
david burton
M7
kamilian2 wrote:175/60 R14
195/50 R15
205/45 R16
It should be ok. If You buy wrong size You will have a problems with speedometer.
i wouldnt use that as a guide though as the rim width is the important thing here
my new rims are going to be 9j on the rears, in theory i'd be needing a 235 or even a 245 on the rear and its still only 16" in diameter....but im going to be stretching a thinner tyre over it
it is no problem about rear rims I wrote about front. here u have calculator - left side are series tyre right are new
http://www.v10.pl/narzedzia/Kalkulator, ... n,204.html
