I have a 2003 1.4 TDI SPORT and i have noticed when traveling especially at night with my lights on there is a click from under the dash (under the light switch area) and the lights dim for maybe only for a second and then come bright again like when you use something that uses alot of power it can do it a few times. I thought it might be the cooling fan but it does it mainly when the car is cold. My aircon is off too.
Any ones 9n do the same??
Also my brake lights kept sticking on and when i rattle the peddle they would go off. But tonight they finally dicied to stick on on! The glow plug light started flashing to warn me. It took me ages (in the local garage VERY
imbarassing) to get them to go off. They are now off and the glow plug light has stopped. But it has left 2 fault codes (16955 brake light switch i know) but there is one i cant understand
17978.
Any ideas?? Many Thanks
