Want MP3 but dont want to change the HU then look in .....
Discuss In Car Entertainment
nickp34
Post by nickp34 »
Have a look at the MP3 XcarLink. The device connects to the standard HU and acts as a MP3 player. It can be controlled via your HU buttons. Works with the VW Gamma, Beta, Delta, Delta6, Monsoon, PE2, R100, RCD200, RCD300, RCD500. It has a USB port, SD card slot and a 3.5mm line in. You can store the songs on a memory card, USB pen drive or portable 2.5" USB HD. Line in can be used to connect a MP3 player like a Creative or Ipod etc.
This device will work even if you have a cd changer currently connected to your stereo. No need to disconnect it.
If you have an Ipod there is an Ipod version that lets you connect your Ipod to the factory HU, control it via the head unit and also charge it.
3 models of Xcarlink available for the Polo:
http://www.xcarlink.co.uk/bmy_search.ph ... model=Polo
How it is installed:
http://www.xcarlink.co.uk/pages.php?pageid=2
I received mine today. Keys to remove the factory head unit are provided with the XcarLink. Installation was simple. I have located the unit in the glove box. The cable can easily be passed from the glovebox to the back of the head unit. Nothing is visible with the glovebox closed.
It works great and I am very happy with it. :)
For pictures see:
http://i141.photobucket.com/albums/r73/ ... 29974e.jpg
http://i141.photobucket.com/albums/r73/ ... 2c857f.jpg
http://i141.photobucket.com/albums/r73/ ... 83ee7b.jpg
http://i141.photobucket.com/albums/r73/ ... 0ebb6a.jpg
http://i141.photobucket.com/albums/r73/ ... 139b89.jpg
Nickp.
nickp34
Post by nickp34 »
I received mine today. All installed and working. Original post updated with pictures.
Nickp.
Zero-Tolerance
Post by Zero-Tolerance »
does this work on mp3 players such as the creative vision:m?
thanks, Alex.
nickp34
Post by nickp34 »
Any mp3 player will work.
PHILIP1193
Post by PHILIP1193 »
can you also use the cd player or does it remove the connection completely?
Phil
nickp34
Post by nickp34 »
It does not disable the built in cd player or external cd changer if you have one.
