Attaching Pressed Plates?
Yourmum90
Post by Yourmum90 »
Ok i have been looking at three forums in the last 2 days and no where have i seen how these plates attach, I am looking at getting UK pressed plates from Dubmeister.
2 questions really A, how easy is it to get off the original plates on a new polo GTI. The other is how to attach the new plates with the surrond and without.
i am guesing it will be a velcro or sticky back plastic blue peter job but just incase.
oh and i am not asking what is legal and stuff
bobtknob
Sponsor
Post by bobtknob »
i used plate holders from the plateman.com which screw to bumper or bootlid
then the plates slide in and the edges click in to hold it
but if you dont want holders use double sided tape or similar, or drill the plates and use screws
upto you!
Yourmum90
Post by Yourmum90 »
thank you for your very speedy reply, any ideas how the original polo gti plates are held on?
bobtknob
Sponsor
Post by bobtknob »
no idea buddy
check the front of the plate for screws
if they are in holders they are most likely stuck on
just have a look
david burton
Post by david burton »
my plates were stuck on with industrial stuff, was a complete pain to remove but got there in the end with a lot of white spirit.
to put on my pressed plates I used velcro from Focus DIY / B&Q, It's about £3.40 a metre for both sides included.
Make sure the surface you apply them to is pristine! They've held for a week now, so all is good.
Then if the cops ask me to remove them, I have the other ones in the boot good to go with velcro too.
apparently there is a grey area regarding whether EEC plates in the UK can actually be legal - keep an eye on dubmeister for updates, it may look like you can actually argue they are legal from now on.
tomadomeit
Post by tomadomeit »
The stuff in the pic above is good for it. I have it at my work if you want some pm me :wink: :wink:
Tim_GTi
Post Whore
Post by Tim_GTi »
Just use trim repair tape, it's fancy double sided tape you can get from halfords. Really sticky and saves drilling the bumpers further!!
You OEM ones are probably screwed in, pop the caps off the two covers and it'll expose the screws.
I was a bit disappointed when I found that the plastic UK plates would not fit inside the Euro mounting frames - material too thick, but surely its only a matter of time before pressed plates are used in UK again as these plastic ones are rubbish!
Tim_GTi
Post Whore
Post by Tim_GTi »
Pressedplates are soo much better. Looki better, they're still reflective, and last alot longer than the plastic ones! You see so many with moisture leak in them clouding the reg number...
Tim_GTi wrote:Pressedplates are soo much better. Looki better, they're still reflective, and last alot longer than the plastic ones! You see so many with moisture leak in them clouding the reg number...
Yes and that then becomes an MOT failure!!
Mouse_GTI
Post by Mouse_GTI »
I also use the heavy duty Velcro stuff
JPR_polo_gti
Post by JPR_polo_gti »
Mouse_GTI wrote:I also use the heavy duty Velcro stuff
same here top stuff
Tim_GTi
Post Whore
Post by Tim_GTi »
same here top stuff
I'm scared it's gunna leave marks on my bumper!!
I know it's not, but it would worry me.
vw-po-low
Post by vw-po-low »
I used Velcro strips for mine. Got them from Tesco! My plates have never moved :D
