lowering tips - everyone with a gti please give some advice
shantybeater
Post by shantybeater »
Hi guys, I was just wondering what everyone has their gti lowered to and with?
Ideally I don't want to faff about with coilovers, to me its not worth the extra cash to be able to adjust the height. Has anyone got photos of cars on springs? i was looking to lower around 60mm i think..baring in mind i will be running 16's hopefully on 195/40/16's
Ollie_R
Sponsor
Post by Ollie_R »
I was lowered 60 front, 40 back on the 16" RXII's last year and it looked spot-on, and there was a bit of arch-gap left over.
Here's a pic from Santa Pod last year
Theoretically, you could go lower than 60mm with the wheels on, as they're only 6.5J wide and sit rather well inside the arch.
There was no rubbing at all, only when I put spacers into the equation, things started to get a bit dodgy.
shantybeater
cool how much did your kit cost? I assume there will be no difference between yours and mine & i could get the same kit?
I assume I couldnt go lower without getting coilovers?
Ollie_R
Sponsor
Post by Ollie_R »
It cost £140 from Mr. Jackson (PhilJ) on CP.
You can go lower than 60mm on springs and shocks, there's both a 75mm and 80mm kit available on CP.
I'm not sure about whether they will look the same, the GTI is already lowered 10mm as standard, but I'm not sure whether that is in regard to the standard springs/dampers or the whole suspension setup.
Also, here's another example of a GTI on the 16" RXII's:
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=29543
Cyhliu's car looks spot-on 8)
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Cyhliu's car is on the Eibach Sportline springs, does look rather smart. Was the inspiration to do similar with mine essentially.
shantybeater
whats he lowered to? i'd like to go a tiny bit lower if I can get away with it
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Eibach Sportlines are 50mm front and apparently 35mm rear.
mk4 glx 1.6
Post by mk4 glx 1.6 »
In my opinion the Eibach Sportline springs give pretty much the perfect ride height for the 6n2.
If you want to go lower, the Phil Jackson or ebay kits are your only option bar coilovers.
This is olop_Chris' old gti on the 60/60 kit (rear adjusted to -60):
shantybeater
60/40 kit looks good as they are 15's so mine should looks swwweeeet, thats if i'd get away with it???? that looks slightly lower than yours ollie??
Ollie_R
Sponsor
Post by Ollie_R »
Chris had the rear adjusted to 60mm, and mine's currently at 40mm (not for long, however :mrgreen:).
cyhliu
Post by cyhliu »
Thanks for the nice comments Ollie, I've been very happy my Sportlines although the ride can be a littel harsh sometimes but I think thats because of the London roads more than anything else!
shantybeater
cheers for all the replies guys, think i'm gonna go for the 60/40 kit, any lower will prob cause problems, alot of lush looking polos, cyhliu yours is along the lines of what i want mine to look like, are those standard brake calipers?
I assume it will look better leaving the back on 40?? or would I go 60-60
pootas
Post by pootas »
Anybody got a link to the best place to get the Eibach Springs with a 60/40 drop??
mk4 glx 1.6
:roll: here. The Eibach Sportline springs give lowering of 45-50 Front, 30-35 Rear NOT 60/40.
