Once i got home i turned off ma engine and push my clutch pedal in and there is a horrible grated/springy noise??? Is this somethin to worry about, cos ma car is runnin fine and so is the gear changes etc??
Clutch :(
- KennyPOLO_Gti
Clutch :(
On ma way home from work i was racing my mates Type R. When we both approached the roundabout there was a horrible grating kinda noise but both cars seemed totally fine after.
- KennyPOLO_Gti
- KennyPOLO_Gti
Switch it back to the original software thenKennyPOLO_Gti wrote:Think a will ill see how it is tomorrow. Hope they dont take it out and realise its been remapped tho
The new polo's are able to have 2 different programs in their ECU. I can switch mine back to original if I want to (with vagcom).
I hope the tuner has left the original one.. If not that would be kind of amateuristic..
PS. Why are you typing A for I and Ma for Me ?
- KennyPOLO_Gti
- KennyPOLO_Gti
Even with a remap it shouldnt affect the gear box warranty, because the remap hasnt got anything to do with the gearbox etc, vw will do anything to blame a remap on anything that fails on the car.
Ray
Ray
is it a proper mechanical noise or just a little one inside the car
as my red polo gti did this little internal noise, it was the clutch pedal mechanism just wanted greasing mate
hope its just that and it helps
my door is currently making the most annoying sqeek when it opens and closes too, iv greased it all up but its still doing it slightly
A remap has got a lot to do with the gearbox.Ray_chan wrote:Even with a remap it shouldnt affect the gear box warranty, because the remap hasnt got anything to do with the gearbox etc, vw will do anything to blame a remap on anything that fails on the car.
Ray
More torque = gearbox gets more beaten up also..
Is someone dreaming here! As Wouter has implied, a gearbox is only made to withstand the engine loadings that it would see in normal service, but there again what an interesting concept - so you could transmit 300HP and huge lumps of torque through a Polo gearbox and it would be okay? Try finding out a little bit about engineering in general Ray_chan.Ray_chan wrote:the torque will go through the flywheel anyways not gearbox.
