hi mate, sorry the reply is a bit late in the day...i'm at work.
In regards to the plugs being spare, can you take a photo of them? or describe where they are located once the loom is in...is it the interior loom or the engine loom?
ALSO...
The way i'm doing my conversion is...i've swapped the engine harness for the GTI one so its all plug and play...the interior loom is now a mk5 1.4 mpi one so the engine harness plugs into that.
What i've got is the little black box which has the immobilisor code stored inside it and its situated above the headlamp switch inside the dash on a mk5.
On a mk4 its under the steering column...
I swapped the boxes over, the key i have that is coded to that particular black box/ecu i have also...i.e. the GTI key.
so my plan is to take it somewhere to have the chip taken out of the gti key and transplanted into the mk4 keys...the firm will find out whats on the chip and reprogramme my own keys to suit.
On the mk4 i didn't change the ignition barrel because thats NOT where the chip is read, the ring transponder coil AROUND the ignition barrel is the reader of the key chip...when the key comes close to it (i.e. inside the barrel) the code is sent down the wire to the black box and it disarms the immobilisor...or so i hope thats what will happen!
The ring around my ignition barrel was bigger than the mk5 one, so i had to rewire that to suit, you won't have that problem...all you need to do is swap your black box over for the GTI one and take the two keys somewhere to have them coded (vw does it i think...)
Sanj.
