[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Tdi brakes = GTi brakes?? - UK-POLOS.NET - THE VW Polo Forum
The fronts will defo be the same (well, they are on lupo's), should be 256mm vented by 20mm thick, running seperate caliper carriers, unlike lesser models which use 239mm discs with carriers built in to the hub. I didnt realize tdi's had discs to the rear, but they will be the same if it does.
