Changing springs....how hard is it?
tegwin
Post by tegwin »
Im looking at buying a GTI thats been lowered, however I cant actually get insured on a lowered car so im going to have to refit the origional springs:evil:...
How hard is it to swap the springs over?
Will changing the springs effect the current camber and tracking?.... (will I have to get it retracked and have the camber looked at once the old springs are back on?
bhp addict
Post by bhp addict »
not too difficult afaik -
i will be doing the reverse and fitting 60mm drop springs in next couple of weeks myself
Yes you will need the camber/tracking done - local garage should do it for you - around £50ish apparently mate
hope this helps 8)
Bryony84
Sponsor
Post by Bryony84 »
Not too difficult, I did the reverse of this a few weeks ago - its time consuming and you'll need some spring compressors but its not difficult.
Tim_GTi
Post Whore
Post by Tim_GTi »
what are you based? and how low is the car? fancy swapping springs? I know sum1 who can do the whole sheebang
TheEggShell
Post by TheEggShell »
Hi guys,
Does anyone know the part number for the standard front suspension springs?
Also, is there a guide anywhere for changing springs?
tegwin
Post by tegwin »
Im fairly sure there is a good guide to replacing the strut/springs in the appropriate haynes manual....worth every penny IMHO!
sorted
Post by sorted »
No one will notice if its only a 30-40mm drop :lol:
