vag com
mk5coz
vag com
Post by mk5coz »
does anyone know what version of vag com works with the polo gti on a 2000 model as i have a version but it says it cant communicate with the car. any help appreciated
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
I used 409-1 i think it is, make sure you have your com settings set correctly
hope that helps mate,
Haris
mk5coz
Post by mk5coz »
wot are the com settings?
h4r1s
Post by h4r1s »
Go into device manager by right clicking on the my computer icon, then select the device manager tab, then find your cable driver, right click > properties and there should be com settings somewhere set it to comm1. Then make sure you have it set to comm1 in vag com as well and it should work hopefullly.
Hope that helps,
Haris
s-l-i-x
Post by s-l-i-x »
Is it worth me buying vag com and the cable? What exactly can you do with it?
h4r1s
Post by h4r1s »
You can check for fault codes, clear fault codes which can be helpful for passing your MOT if one of the lights happens to be on and it has other features which i'm not too sure about though.
polo_gti21
Post by polo_gti21 »
vag com is a good idea but if you get curious and push a button you shouldnt its a lot of hassle to put right which has put me off this way but there is a fault code reader avaliable from gendan which you can read the fault and clear it. check it out
http://www.gendan.co.uk/vag_diagnostics.php
