URGENT HELP!!!! Problems with front coilovers
Dub1
Post by Dub1 »
Having problems with my front FK Konigsports coilovers, fitted the offside but as i let the jack down this happened...
this is the setup of the coilovers with everything that i have with them
i guess there is something missing, i.e washers??
Not a definative answer, but, have you not left out some of the original bits that need to be reclaimed and used with the new struts - like the top platform or bearing assembly etc? The new top spring seat is okay but you still need other bits.
BAZ C
Post by BAZ C »
youll need to use parts off the original struts
more than likely youve left off the top mounts/bearing assembely
kc
Drives: an imaginary one... for now
Post by kc »
the top mount is missing, you need to take apart the old strut and the black bit with the 3 mounting holes in it you need to bolt your new strut to that, and the old top mount to the top of the turret!
