[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 How NOT to fit a Short Shifter - UK-POLOS.NET - THE VW Polo Forum
Got mine today so thought I'd give up studying for my exams to fit it today. Instructions show a passat (I think) centre console where all you have to do is undo a few clips/screw then its out. Of course the Polo HAS to be different!
No screws or anything so I got out the Haynes manual. It told me to first remove the black plastic bit underneath the steering column, held by 3 screws. Done the middle one first. Fine. Done the passenger side one, it was a different size but I found it. Fine. Move onto the one nearest to the driver door and the bit didn't seem to fit in with the screw head. Tried for 30 mins with heaps of different sizes and about 3 of them fit, but they kept slipping no matter how tight my grip was.
So basically I got a screw that won't budge and if I want to fit my short shifter, I'll have to snap the underside of the steering column off
1 GTI wrote: Am I right in thinking a short shifter are like F1 cars?
Ermm....no.
A short shifter, shortens the throw of a manual gearbox. I'm guessing that you're somehow confusing that with a sequential gearbox which is a completely different principle altogether.
I left some tips in the other thread... I guess you missed it
anyway this is what I found
pretty straight forward to fit, the only fiddly bits was removing the centre console as there was a bit more to it than in the instructions.
you have to remove two torx screws either side in the footwells
two others behind the coin tray
and two plastic nuts where the gear stick is, then it just lifts out, a bit fiddly trying to push it to the side but found it easiest to push it to the drivers side and have part of it sticking out the open door.
the other tricky bit was removing and replacing the pivot rod, as it's a bit low and hits a nut and even if you remove the nut it touches the side, there's another nut that releases the stick mechanism which lets you tilt it a bit but it's still a bit of a squeeze.
finally the pin it comes with snapped on me while I was testing the gear engagement....it seems a bit flimsy and the original pin is too fat, so I used one of those little rings that you get on keys? sorry don't know the name, it was a tiny one about 8mm in diameter, a bit tricky to get on but it works brilliant, been driving around all day and it's makes a big difference, it's so easy to change gear now and so much faster.
oh and forgot to mention that the knob doesn't screw on like it says it should... I just fixed it with a jubilee clip
Almost done fitting it, been at it 4 hours but got a problem. Was engaging gears and we couldnt get reverse. Then we heard something fall off then the clip for securing the pivot rod came off. We are finding it hard to secure it. Any tips?
Ok the first thing that did fall off was the clip. It hasn't snapped but is bent out of shape. Does it need this? I need the car tomorrow for work and we don't have any washers suitable.
The older kits came with a metal bracket thing, so why one earth did they replace it with a s**t little clip?
Ok we bent the small pin into shape, and the securing metal clip for the pivet that fell off, we tightned in a spanner and it seems to be sitting tighter. Can engage all gears now. Not driven the car though. Not too confident about it though, just because of the two crappy fasteners. Also disappointed the gear knob doesn't screw on
JPR_polo_gti - how did you attach the gear knob with a jubilee clip? Any problems since?
haven't had any problems since,
to attatch the gear stick I just took off the old ring clip thing that was there, and put a small jubilee clip in it's place.
the gear knob was still turning a bit so I took off the gear knob and wrapped a small elastic band around the area of the stick where the jubilee clip would need to grip, bit crude but it's done the job nicely lol
An hour, that's madness lol. I suppose it was little things that held us back. For the main part most of it was straightforward, if not a little overcomplicated at first. Haynes manual is crap - says remove 6 screws in one section, you end up removing 12 or something! B&M instructions are pretty good, especially with the labelling, but the pictures are printed far too small.
The gearbox was fine to and from work. Getting used to it though it feels good. I went down to VAG at lunch to order 2 spare clips to hold the pivot in place. Guy at work reckons the pin that sits at the bottom should be ok if we bent it (which we did). Fingers crossed!
