How to put number plate on the grill at the bottom
Prabz
Post by Prabz »
Got my bumpered flushed and smoothed just wanted to know how to put my number plate where the grill is at the bottom ?
Si_GTi
Moderator
Post by Si_GTi »
Cable ties?
Prabz
Post by Prabz »
Is there a DIY Guide ? becuase i don't know to how do the cable ties :|
Rupy
Post by Rupy »
You'll need to put two small holes in the plate....then climb under thecar and slip the cable ties in from behind...snip with scissors or cutting tool of some sort. Job done.
8)
thedees1
Sponsor
Location: edinburgh/livingston, drives: polo gti red 5dr
Post by thedees1 »
I did mine with 12 x double sided number plate sticky fixers from halfords they work a treat
tomo87
Post by tomo87 »
sticky velcro from halfrauds does the job...
Tetsuo_83
Post by Tetsuo_83 »
Could use the cable ties coupled with a plate surround...
Cable ties through the holes in the surround, mount that to the grille, then just pop the plate in... would even make it easy to switch between legal and german plates.
Mouse_GTI
Post by Mouse_GTI »
I was about to ask this question. Anything to use so that you don't have to drill holes or put cable ties over the plate? Everyone sure about that Velcro stuff in Halfords as I use it on the bumper and the back just peels off the plate, and there would be less surface area on the grille wouldn't there?
JPR_polo_gti
Post by JPR_polo_gti »
cable tie the velcro to the mesh
Mouse_GTI
Post by Mouse_GTI »
Now that's an interesting one. I was thinking of some sort of clips to put behind the plate, then tie something through them
thedees1
Sponsor
Post by thedees1 »
just stick with the sticky number plate fixers, they do the job great. When it comes to taking the plate off the grill ,a little pull and its off.
Arnoldo
Post by Arnoldo »
Cable tie the number plate surrounds to the grill (no drilling required) and then put ur plate into the surround. Also means as stated above that you can have german plates on and change them to fully legal ones in less than 30 secs ;)
Mouse_GTI
Post by Mouse_GTI »
thedees1 wrote:just stick with the sticky number plate fixers, they do the job great. When it comes to taking the plate off the grill ,a little pull and its off.
Cool I'll chance it then. Is that the actual name of them?
thedees1
Sponsor
Post by thedees1 »
yip they are normally on the parts desk at your local halfords, its the thicker ones remember, if you get the thin ones it wont stick (i found out the hard way)
