Rear Aero Wiper
Posted: Tue Jan 13, 2004 12:14 pm
by des_pd_ tdi
Apart from looks does this actually give you a benefit from the original pre 2003 version fitted?
Des
Posted: Tue Jan 13, 2004 2:00 pm
by Mike_T
I fitted one last weekend to my Polo 6N2 GTi and it's just a cosmetic mod.. although perhaps the aerodynamics are better!?
Posted: Tue Jan 13, 2004 3:46 pm
by Clawz
I always found that the old wiper didn't really clean the back window whereas the new one actuallty seems to do a sterling job :P
Posted: Tue Jan 13, 2004 5:16 pm
by SiDaBa
Exactly what Clawz said, mine used to be all smeary and now it wipes really well and i can actually see out of the backwindow when it's raining! :lol:
Posted: Sat Jan 17, 2004 10:48 am
by bertJ
Our 9n has been back to the dealer twice in an attempt to make the rear aero wiper clean correctly. The wiper misses a patch in the middle. It's still not sorted.
Posted: Sat Jan 17, 2004 7:07 pm
by tim
yeh, mine was fitted as standard to my 9n, i thought it was good too until it stopped wiping the top half of the rear windown and the water jet only reaches up half as far as its used to, it sucks,
any ideas?
Also when the front wipers are on at full the left one hits off the A pillar
Posted: Sun Jan 18, 2004 3:20 am
by alex
tim wrote:yeh, mine was fitted as standard to my 9n, i thought it was good too until it stopped wiping the top half of the rear windown and the water jet only reaches up half as far as its used to, it sucks,
any ideas?
Yeah have you tried adjusting the washer jet? It might sort the problem if not then it may be losing pressure somewhere, try shaking the tailgate up and down if you hear water sloshing around then you have a leaking pipe also check under the boot carpet for dampness and water leaks under the engine bay toward the back near the bulkhead as the connection there can become disconnected.
With the wiper hitting the A pillar if you loosen the nut on the spindle the arn is secured to you can adjust where the arm rests and should solve the problem.
Hope this helps :D
Posted: Sun Jan 18, 2004 12:28 pm
by bertJ
tim wrote: Also when the front wipers are on at full the left one hits off the A pillar
tim:
Just to depress you - the front wiper on ours also hit the A pillar. I tried removing the wiper arm to re-locate it but the arm wouldn't come off despite Plus Gas and WD40. In the end I borrowed a puller from a mechanic friend. Apparently the soft alloy of the wiper arm 'bites' into the wiper spindle splines and virtually seizes into place. You might be lucky but don't remove the nut completely when you try to remove the arm because the arm may come off in a rush and go flying, scratching you and the paint! Once the arm is loosened you can remove the securing nut.
Unfortunately re-locating the arm didn't do much good as there seems to be too much travel in the mechanism. However, it only hits the A pillar on high speed now. The dealer said they would replace the whole mechanism under warranty but the car is being sold shortly so someone else can have the headache.
Posted: Sun Jan 18, 2004 12:40 pm
by Josh_PoloGTi
My rear aero wiper has recently started missing a bit in the middle of the rear window.
Pain in the ass!
But the wipers are sooo cool, so I'm not bothered!
