Rear discs for New Polo
Gonna be picking up me Polo this Saturday with 16" wheels on. Trouble is, I'd love to get some discs for the rear wheels...just don't feel happy having drum brakes under there.
Any suggests?
Any suggests?
Have a word with AMd based in Biscester Oxford, they should be able to sort you out. But then again you still have ABS, I think the only benefit would be that they'd look asthetically pleasing.
Think about warranty invalidation though, I know I go on about this but the warranty is the reason people buy new cars these days. Well I did anyway
- Moderator
I'm sure it can be done, only problem would be the abs. If you go on www.porka.net (not sure if you wanna delete that Josh) there is someone with a MK4 who did the same thing, not sure if he had ABS though
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
It should be possible.
JBS Auto Designs in Chesterfield (01246 550 400 - www.jbsautodesigns.co.uk) were going to fit some rear discs to my MK4 before I sold it... I think they were going to come from a MK3 Golf GTi?
Give them a ring and see what they say
true the abs sensor tyre and position are the only main concerns but you may also want to concider the brake balence front and rear as this will prolly be changed but can be compencated for by fitting a brake compensator (if you dont already have one) and this can be set up roughly with a set of axle rams and then finally on a brake tester like you see at mot stations. the abs is not a main concern because the sensor sees that the wheel is locking up and then the brake is released and re-applied by the abs valves and auxallry pump which are all under the bonnet (look for a melal block near the servo with 4 copper lines going in and one braided stainless steel one)
I'm not sure exactly. It is either standard on 2003 models, or the sport from 2003 onwards. Mine has discs all round but I've seen a sport model with drums.
Looking in the 2003 catalogue it shows an SE model with drums. Although that doesn't really prove a point either way as it's probably an 02 model, actually it is as it doesn't have the aero wiper!
James.
James.
- Moderator
