polo gti alignment/tracking/camber etc...
shantybeater
Post by shantybeater »
Hi guys, i've been ringing round garages to get my alignment sorted since my ride height has been adjusted, and the local place quote £30 but it may be £60 if the car has two aligment points? is this true? and does the polo have two or one?
I phoned another place and they just said £30 + vat and mentioned nothing about it?!??!
Bit confused
Bryony84
Sponsor
Post by Bryony84 »
Make sure you mention camber as well as alignment. You will probably get told you can't adjust it on the Polo, but you definitely can!
I got mine done at Protyre in Fareham, not sure if they have an equivilent branch near you?
shantybeater
yup went to protyre here and got it all done for £59, although they told me my camber is max'd on the right wheel so they couldnt adjust it anyfurther unless I raise the suspension....they'll do it for free though if I do
tomo87
Post by tomo87 »
they said that to me...theyre pretty rude and useless in there and i wont be going back again
kipper
Post by kipper »
if u live near farnham give farnham tyres and exhausts a call. i used to go to kwik fit as they are just down the road from me in aldershot but since i went in there and asked for my allignment to get done and ended up coming out with a £300 bill i decided im never going there again.
ive taken my gf's car to farnham tyres and exhausts befor and found theyre friendly and usefull so i'll be using them as i need new front tyres soon and prob see about getting the allignment and camber checked to.
Ian_R
Post by Ian_R »
You can only adjust the camber on the Fornt of the car, as the Back is a solid rear beam, So when lowered there isnt anything you can do about the camber, But as mine sits it aint bad at all, and only the front is a pain in the ass.
Although when i got my coils i also purchased a set of H & R camber bolts. and it made a massive differnce. to when the coils where first put on and then the full aligenment done. Altho the camber looked 8)
kipper
Post by kipper »
wat are H&R camber bolts? and wat do they do? how do they help?
