tracking/camber settings
steve p
Post by steve p »
will be fitting a suspension kit to my gti soon, anyone know what the track/camber should be also i will need the headlights sorting as they need adjusted some how
Si_GTi
Moderator
Post by Si_GTi »
You will need to have your headlights adjusted, yes. Get it done at your local dealership as it requires the VAG-COM or equivalent to reprogram the levels. Will cost anything from £0 - £30.
As for tracking and camber, both must be done after lowering without fail, as both will be out. I don't know the exact values you will need for these though, just that you will need to do it. I took mine to a garage and had it done.
Plenty of topics on the forum if you have a look around or do a search ;)
Hope this helps
Tim_GTi
Post Whore
Post by Tim_GTi »
Camber and tracking should cost around 40-60
As Si said, theres loadsa info floating about
andyniceday
Post by andyniceday »
are you sure you need vag com to adjust your headlights?
i found a screw in the back of the headlight unit which you can just turn to aim them up or down :?
tomo87
Post by tomo87 »
the screw wont actualy adjust them...you need to get it plugged in but its only a 2minute job, alex did mine the other day
ModifiedMadness
Sponsor
Post by ModifiedMadness »
As above.
From what I've read, the screw will adjust them, but they won't stay like it!
Tim_GTi
Post Whore
Post by Tim_GTi »
ModifiedMadness wrote:As above.
yeh they'll just reset themselves after a while.
I need mine adjusting and havnt even got it lowered, just getting the time to go dwn the dealers
bristolgeezer
Post by bristolgeezer »
i adjusted mine on the screws and they've stayed the same and not reset themselves and that was a while back!
i went to vw monday to get them to look and my offside light cause the adjusters missing and they said i need a new light cause they cant supply just the adjuster screws :( its a bit low but its not 270 quid low is what i told them!
steve p
Post by steve p »
thanks for the advice guys, must get the suspension kit fitted to the polo
