This is doing my head in......Im not very mechanicaly minded but ill give anything a go as i did with my windows.
My passenger side window stopped working on me so i took the door card off had a look at what it could be, When i was flicking the switch i could hear the pump clicking but nothing happening, So 1st i change the regulator and have a go and no luck, so i take the regulator back and get a new pump instead, Change the pump and still nothing. What else could it possible be ?? Someone said it might be the fuse but then said Oh if it was the fuse it wouldn't be clicking.
Anyone had this problem and no how to fix it ??
Any help would be great.
Omz
6N2 Electric F*****g Windows Arghhhh !!
Hey lads, Finally think i found the problem, Like Benno and Sorted suggested i had a butchers at the wirering between the car and the door and the thick brown wire has split in 2, Im hoping to get a connector on their to link both ends up again and fingers crossed that should sort it.
To think it's something so simple, i went down the route of changing the regulator & motor which is prob what a garage would of told me if i hadn't of known any better and all it is, is a split wire
Omz
Omz
