Come off a square, dunno for sure if they'd fit a coupe.
The bottom clips are broken, tried to get them off carefully but either the trim itself was going to break or the dobber on the back was going to snap, so I thought it would be best to try and get the dobber off but if it broke it wasn't the end of the world. You can still clip it in with the one thats on it but you may need to double sided foam tape the bottom part down. There is meant to be foam tape at the top as well so if you put it there would stop it from rotating. You should really put tape on there anyway.
£10 delivered. Considerably cheaper than having the holes welded up and that part of the panel reshaped to follow the lines of the arch!!
I don't really use here very often, so probably best of being in touch on Club Polo (same username).
