Creaking suspension (again, I know...), but please help!
Dezmoand
Post by Dezmoand »
Hello all..
I've got a 1.2 64PS Twist with suspension that creaks when going over speed humps. The sound only comes from the front passenger side since I've driven over humps one side at a time and the drivers side makes no noise. I've had this problem before and the ARB bushes, drop links and consoles incl. bushes were replaced under warranty. This fixed the problem for 5 months... but it's come back now and my warranty has just lapsed!! Considering the number of times my car has been back at the garage, I decided to get VW UK involved. They tell me that they will investigate the re-occuring fault and maybe provide me with some sort of good-will, but they have advised me that they will require a diagnostic report from the stealers @ 98/hr +VAT labour. Also, my confidence in VW UK's goodwill has dampened having read posts about members previous dealings. With this in mind, I don't like the idea of a potentially huge bill and no guarantee that it won't re-occur another 5 months down the line. So despite the fact that I've booked my car in for the diagnostic report, I am having second thoughts about going down the VW UK route.
From reading around this forum and briskoda.net, I am fully aware that this is a common problem on a large number of VAG models (mainly due to the rubbish voided console bushes). But I have also read that it could be down to the ARB/ARB bushes/drop links/front lower wishbone bushes. I've had a look at all these things bar the ARB and front lower wishbone bushes, but they all seem fine to my untrained eye.
I am considering doing it myself, but I have no idea what could be the cause. Has anyone else had similar problems and where should I look first?
If it is the console bushes, I'll probably upgrade them to the cupra non-voided ones. I've found a tool at www.bonustools.co.uk to do the job, but at 189 quid, I would prefer to have a VW specialist do it for cheaper. Can anyone recommend a VW specialist in the London or Bristol region who has had experience changing the bushes?
Sorry for the long post, but please please please help if you can! :(
Jamo
Post by Jamo »
New console bushes.... I squeezed mine in with a liberal coating of washing up liquid and a bloody big vice. Worked fine - just make sure you get them the right way round!
Dezmoand
Post by Dezmoand »
Did you upgrade them to the cupra bushes? or were they the standard polo ones?
Also, did it cure the creaking?
Jamo wrote:New console bushes.... I squeezed mine in with a liberal coating of washing up liquid and a bloody big vice. Worked fine - just make sure you get them the right way round!
A word of warning here, all the front suspension "floats" at its mounting points - ie all fixing screw holes are over sized, this includes the lower cross member and the TCA outer ball joint. In reality this means that if you take the consoles out to replace the bushes then you will have lost the correct postion of the cross member and camber & caster will be out and tyre wear and road holding could be impaired until you get a full four wheel alignment done. If you buy the "bonustool" bush thing you will escape the realignment problem and cost. With that in mind the price for this tool looks okay. I got a VAG indep to change mine so could not really justify buying this tool - especially as I got the Cupra bushes fitted. Another tip is that VW sell "fitting lubricant" for this job - my indep looks like he used copaslip when he replaced the one he made a mess off.
