Hi im kinda new to the veedub scene and rarley come on this site, but i wonder if you guys/girls could help me out, at the moment i have a 2000 reg (W) Polo, 1.4 SE., and was wanting to find out how easy/hard it would be putting a GTi engine into it?. Going to make it my 'sleeper' car :p
Thank You.
GTi conversion?
Mk4 Polo MPI
Mk4 Polo MPI
dubbprince
if you can get the following:
engine, gearbox,
exhaust system (complete manifold to rear box setup- with both lambda probes intact),
Ecu,
engine bay wiring looms,
clocks,
pedal box,
all ancilleries (all hosing for the engine),
Anything else such as brakes, suspension you want changing then i can do it cheap...and i'm in northampton.
We're talkin £500 drive in and drive out.
(i'm flexible on price if you find cheaper elsewhere)
For the above it'll most likely set you back about £600-900, maybe more depending where you get it from. Best to find a crashed GTI.
engine, gearbox,
Ecu,
clocks,
pedal box,
Nah alex your being unfair to the GTI conversion dude!
I reckon we done it all for about 1k.
I got:
Engine
Gearbox
Ecu
Complete wiring loom
Clocks
Front brake set up
Rear brake set up
GTI ARB's
All for about £850
I spent another couple hundred on other stuff, that arent really required....i got new wheel bearings, brake discs, pads and hoses etc etc
So i reckon it can be done yourself for about a grand.
Or you could save yourself the leg work and pay sanj to do it, since he has the experience of doing it to a mk4
Just to let you know, the pedal box isnt a must.....i kept my original 1.4 8v pedal and its been reet since the start.
It really is an easy conversion! Could be done within a couple days i think if you have good knowledge of it
I got:
Engine
Gearbox
Ecu
Clocks
Front brake set up
Rear brake set up
GTI ARB's
All for about £850
