can i even be bothered to rant about my damn central locking
JoeG07
Post by JoeG07 »
well central lockings buggered AGAIN damn useless thing! Its an electrical problem rather than a problem with the pump, anyone got any ideas? Its remote central locking, none of the doors will ever unlock unless done manually. All the doors lock using the remote. I've been told its likely either the motor in the drivers door, or the 'control box' wotever that is.
I've conclued its not the pump because the pump makes no sound, if it were an air leak you would hear the pump wurr but with no action, you can hear the pump whurr when the doors bother to lock.
VOLKSWAGEN QUOTED £110 JUST TO DIAGNOSE. Sod that for value 4 money, the cars only work £1k!
iggy350
Post by iggy350 »
have u checked ur pump m8? cos when mine went before it made no noise what so ever. If i was u id just check the pump and its circuit board for mold :P
if its not that then i dunno what to suggest. :/ maybe go to the scrappers and rip out all the door units for the central locking :( not a plesent job.
JoeG07
Post by JoeG07 »
pumps fine
check all your fuses for one. Then check to ensure all the wiring is safe and secure onto the pump.
JoeG07
Post by JoeG07 »
already checked, it works occaisionly and usually locks so no idea
So it locks but wont unlock? That suggests its an issue with the comfort module/controller. I think its located somewhere under the dash. Yours is non-remote am i right?
JoeG07
Post by JoeG07 »
nah its remote, ive seen it unlock vary rarely since the problems but locks every time
