Exhaust emission warning lamp
titan619
Post by titan619 »
does anyone know what needs to be fixed when the Exhaust emission warning lamp stays on constantly? and how much should it cost to fix?
Ben M
Post by Ben M »
mine came on and my car didn't drive right (i drove it 10 metres and noticed it wasn't right) and it was the cylinder coil.
Ben M
Post by Ben M »
oops double post
M7
Post by M7 »
could be one of the coils, the cat or the head gasket
theyre the 3 probs i've had when the light has come on. all 3 were done on warrenty at the time
peterbuk
Post by peterbuk »
Mine was a cylinder coil, had 2 get a nu set
titan619
Post by titan619 »
how much is for a cylinder coil? if you continueing to drive with it on will it damage your car?
GaryUK
Post by GaryUK »
When mine came on was just a faulty sensor, best get it checked out though!
ihpj
Post by ihpj »
You'll need to see if there is a fault code as if you go replacing items willy-nilly then it might cost you more in the long run, and if the fault persists despite you changing unknown parts, you might do further damage to the car. Get the fault code read mate and go from there.
As for coils...shouldn't they be replaced in sets and wasn't there a recall for dodgy coils by VW on the Polo?
AKs_SlickPolo
Post by AKs_SlickPolo »
It could really be a whole heap of things. But normally it will be either the coilpack or the lambda probe. But, it can just in some cases be a 'false alarm'.
I agree with ihpj - get a diagnostic scan of your car then take it from there.
FUTUMSH
Post by FUTUMSH »
mine was a hole in a vacuum hose which went to the turbo,(diesel 1.9 model).
Ben M
Post by Ben M »
titan619 wrote:if you continueing to drive with it on will it damage your car?
yes.
as people have said, get a diagnostic machine on it.
titan619
Post by titan619 »
i have got a M.O.T next week will they find the problem then..
Harald73
Post by Harald73 »
I had the warning light on and the reason turned out to be the EGR valve.
Had it replaced (for not so reasonable price of 310€ (50€ for diagnostics and 260€ for the valve + work) and avot, works like a clock.
P.S. Depending on the reason, it might not be so dangerous to keep driving even with the warning light on but it´s better to have it checked asap.
ihpj wrote:You'll need to see if there is a fault code as if you go replacing items willy-nilly then it might cost you more in the long run, and if the fault persists despite you changing unknown parts, you might do further damage to the car. Get the fault code read mate and go from there.
If the car is out of warranty then I'd just change the faulty coil(s) - then maybe buy a new old stock one from ebay for next time - that is all I've done, luckily bought the spare before it was needed and at a good price.
Dubnutty
Post by Dubnutty »
AAAAHHHH stop driving it!!!!
misfire on 1 cylinder=fresh fuel getting spilled into very hot catalytic converter = instant destruction!!
as soon as you get any kind of misfire on an engine with a catalytic converter, you should try and avoid driving it, and if necessary, DO NOT THRASH IT!!!! (thats what I did on my 1.2 polo coz I was SOOO ANGRY and ended up with a near £500 bill!!
