[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Black Rear View Mirror - FOR SALE - UK-POLOS.NET - THE VW Polo Forum
You can either use your original arm as I have done, so just pop off the old mirror at the joint and with a little soapy water on the arm ball that is revealed, pop on the Audi A3 item.....job done
OR
twist the arm that is attached to the windscreen 90 degrees left or right and the whole thing is then released.
