klauster
Posts: 3 Joined: Fri Apr 22, 2005 9:04 am
Post
by klauster » Fri Mar 07, 2008 6:58 pm
Hi there,
Trying to fit some pedals that were supplied by Vagparts.
The Brake and clutch pedal are a doddle, and seem to come off and fit easily, but the accelerator doesnt want to come off.
Anyone done this?
Can you talk me through the best way to remove and fit?
Many thanks,
Klauster
Mouse_GTI
Posts: 2937 Joined: Sat Apr 01, 2006 10:29 am
Post
by Mouse_GTI » Fri Mar 07, 2008 7:07 pm
Try heating it up with a hairdryer or something
Tim_GTi
Post Whore
Posts: 12289 Joined: Mon Jun 25, 2007 6:31 pm
Post
by Tim_GTi » Fri Mar 07, 2008 7:10 pm
Whats it's actually the problem?
Is it some sort of adhesive holding it on? In which case I'd recommend trying what Mouse has suggested.
Or is it generally awkward to maneuver off? IN which case is maybe worth cutting one side of the rubber with a stanley knife to make it easier
klauster
Post
by klauster » Fri Mar 07, 2008 7:10 pm
but should the accelerator pedal peel off too? if so what technique did u use? I cant even see the way it should come off, not like the other 2 which were very easy
Tim_GTi
Post Whore
Post
by Tim_GTi » Fri Mar 07, 2008 7:12 pm
You sure the rubber is still on there? It may have come off at some point, if it's done this simply put the new one on
klauster
Post
by klauster » Fri Mar 07, 2008 8:07 pm
wel there clutch and brake are rubber, but the accelerator seems to be more plastic, ill try ur suggestions, thanks
Dennis
Posts: 179 Joined: Sat Sep 22, 2007 11:35 am
Post
by Dennis » Fri Mar 07, 2008 8:48 pm
clutch and brake pedals have rubber on it but accelerator pedal doesn't!
Tim_GTi
Post Whore
Post
by Tim_GTi » Fri Mar 07, 2008 10:36 pm
Dennis wrote: clutch and brake pedals have rubber on it but accelerator pedal doesn't!
There's your answer!! So i'm assuming the new rubbers go straight onto the accelerator pedal?
Dennis
Post
by Dennis » Sat Mar 08, 2008 9:04 pm
@Tim_GTi: you're right mate!I was fitting TT pedals the other day..
Tim_GTi
Post Whore
Post
by Tim_GTi » Sat Mar 08, 2008 9:19 pm
What pedal rubbers does the new GTi offer? Do they get TT style ones as standard?
Dennis
Post
by Dennis » Sat Mar 08, 2008 9:26 pm
Tim_GTi wrote: What pedal rubbers does the new GTi offer? Do they get TT style ones as standard?
don't know about the GTI because I don't drive it-I
think that they use the TT style as standard!
Tim_GTi
Post Whore
Post
by Tim_GTi » Sat Mar 08, 2008 9:29 pm
Cheers, they should do! They should have been standard on the mark5, the Lupo GTi got them
