electric windows
pip_polo
electric windows
Post by pip_polo »
i know this is somewhere on here but i couldn't find it by searching.
how do you get the windown to be one touch?
when i disconected my battery other week it reset, and annoys me having to hold the button..
cheers
J9NO A
Post by J9NO A »
Turn ignition on (but engine not running)
Lower the window down, then raise it, when it reaches the top of its travel, hold it for 5 seconds (you should hear a click) then it'll be one touch up and down again.
KennyPOLO_Gti
Post by KennyPOLO_Gti »
If u disconnect the battery it seems to reset the limits aswell as the radio clock etc etc. U need fully open and close the window manually a few times once u re-connect. Just for future reference :wink:
Jeff GTi
Post by Jeff GTi »
kenny d/c ing the battery does not lose the radio unless you run an aftermarket stereo
pip_polo
Post by pip_polo »
Jeff GTi wrote:kenny d/c ing the battery does not lose the radio unless you run an aftermarket stereo
the radio was fine. came on straight away, even remembered my pre-sets.
cheers for that, i'll sort it if/when i get my car back.
pidge87
Post by pidge87 »
You can actually reset the one-touch feature by simply pulling both window switches up when the windows are closed. Again as said you will here a click and the jobs done.
I did this last week when i was trying to figure out if the fuse for my fans had blown (which infact turned out to be the resitor pack :lol: )
Just a minor point, if the car has not got its "original" radio, then when the battery is reconnected you still need to enter the key code. I know this as I fitted a brand new Gamma into my imported Passat B5 and it automatically recognises this radio, two years later I fitted this radio into my wife's imported Polo 9N and it recognises it. But the secondhand Gamma I then fitted into the Passat does not get recognised - ever. I'm sure that there must be a way to "register" this other radio with the Passat - anyone know how?
