Would they fit on a mark 4 polo? if so I could be interested I live in SE london/kent. If they do fit hows the conversion go as it looks different to the usual sets I've seen (which is a whole headlight unit).
polo-sib wrote:Would they fit on a mark 4 polo? if so I could be interested I live in SE london/kent. If they do fit hows the conversion go as it looks different to the usual sets I've seen (which is a whole headlight unit).
they are universal mate. They are jsut rings that go on the inside of your current lamp. So they'd look exactly as they do now but with rings around the main bulbs.
they are basically a ring of l.e.d's. they would be best used as stuck on to the front of your lens.. unless you take the lens of the headlight and put it in the inside and then seal your headlight???
anyway..they are probably not road legal.. so advisable to but on the front of the head light so they can be taken of easily.
the size details are on the auction.. you may want to measure your headlight.. and compare to the size of the rings.
your welcome to pick them up.. i would prefer that.
Anyway.. i'm out to the pub.. drown my sorrows after my car failing the m.o.t
Just thought illed say hello as im local so hello lol
