i need some help fitting xenons on my 9n polo.
i need to know if i can i fit the xenon bulbs into the orignal bulb holders or do i need new bulb holders for the xenons?
any help will be appreciated.
cheers.
xenon lights (bulb holders)
- h4r1s
- Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
those aren't xenons,sylvester wrote:If you mean osram nightbreakers or similar they are the same fitting, ie H7
If you are buying a xenon kit all you need to make sure is that the kit is the same fitment as your normal bulbs would be for example H7. You will need to wire up ballasts through the rear of the headlight.
