Hi
I'm new to the forum and would like to know if anyone has a Koni Sport Spring(40mm) and Koni Sport Shocks setup on there Polo GTI 9N
Thanks[/img]
Koni setup
Hi Shanethb,
I had mine fitted a few months ago - really loving the ride because of the adjustable shocks
Only problem is that the rear end is sitting slightly high than the front end,
they say its a 40mm spring, but when I had the H&R 35mm spring installed - the car was much lower than the Koni setup.
I will be get getting a customized rear end spring fitted soon
PS : Post some pics once installed
- whitegtipolo
