Does my polo sport have a Timing Chain or belt?
smokey666
Post by smokey666 »
I've got the 100bhp sport version and its just coming up to 65,000 miles.
So I phoned up a garage to book it in for a cambelt change and they said that my car has a timing chain and not a belt, does anyone know if this is correct?
And if it is a chain will it need to be changed or will it need to be just checked over?
david burton
Post by david burton »
99% sure it's a belt
chewy
Post by chewy »
I have the 100bhp sport and its just had a belt change not a chain. Also got the water pump and the idle pully done too.
smokey666
Post by smokey666 »
thanks guys,
I was suprised when he said it was a chain, I shall go back to him.
newpoloboy
Post by newpoloboy »
Hi
on the subject of timing belts, is the 1.2 65PS model a chain driven one? is there any way i can check it out myself without tearing apart the engine :lol: ..
thanks in advance
The 1.4 FSI is chain driven. As far as i know, only the FSIs and some diesels are chain driven.
I totally agree that the 1.4 16v 100ps has a timing belt - I'd go to another garage if your current one has got their facts wrong - they might just get the belt change wrong. Personally I'd go the indep VAG route and as advised get the water pump changed as well - check up that they was genuine VAG parts, that way they should use a "cambelt kit" and exchange waterpump (cambelt kit has all the idlers rollers tensioner and belt).
As for the 1.2 chain/belt question - they are chain driven - this was the route cause of some early life failures - I think a mod kit is required.
1.4FSI - I thought they were belt driven, all 1.9TDI are belt driven - not sure about the 3 cylinder 1.4 TDI though - common sense would point to chain or gear driven though.
mikehowett
Post by mikehowett »
RUM4MO wrote:I totally agree that the 1.4 16v 100ps has a timing belt - I'd go to another garage if your current one has got their facts wrong - they might just get the belt change wrong. Personally I'd go the indep VAG route and as advised get the water pump changed as well - check up that they was genuine VAG parts, that way they should use a "cambelt kit" and exchange waterpump (cambelt kit has all the idlers rollers tensioner and belt).
The 1.4 TDI is belt driven, I think the only chain driven 9n is the 1.2. :wink:
newpoloboy
how can you tell/check?
thanks
mikehowett
thanks
Just had a look at my Haynes manual and it says the 1.2 has a maintenance free timing chain. :wink:
M7
Post by M7 »
1.2 65 defo has a chain as mine slipped a while back and took ages to get the tool to adjust it
