fan flattens battery
My neighbour has an 02 plate 1.2 12v ibiza and one of the fans keeps running when the ign is turned off, only way to stop it is to unplug it at the multi plug. Have read the fault memories and there is a short to earth fault in the a/c the code was 00705 i think. there are two fans and it is the smaller one that wont stop, i have tried a fan control unit because i have had experieces where these fluff up but that didn't cure it. Any help would be great
shantybeater
I'd just check the Seat forums as advised already - I don't know if www.seatforum.net is the same as www.seatcupra.net either way these guys should help you quickly as these forums are quite active - you could always try the www.briskoda.net site as well but I don't know when Skoda started using this engine.
