Hi Guys,
My glowplug light has started flashing and from reading other posts on here it's apparently due to the brake light switch failing!
Question is, is a brake light switch a dealer item or can they be got from GSF, Eurocarparts!?!?
Thanks,
Ian
Where to buy a brake switch for a 9N?
IansMusical
Re: Where to buy a brake switch for a 9N?
I'd always go to a VAG dealer for this sort of troublesome part as VAG are still evolving it - any aftermarket place will/might just be flushing out their old stock.IansMusical wrote:Hi Guys,
Thanks, Ian
IansMusical
IansMusical
Good, that's the way to do it - having no rear indication of the fact that you are braking is not good - when mine went I sorted it out right away no messing with "I think it might last a few more days as I've cleaned it up" - that's for mugs!IansMusical wrote:Hi Guys,
A new brake light switch for a 2002 9N is £8.14 from the dealer
Thanks, Ian
smithysmoo
where is the brake light switch located???? Cheers I've got a flashing glowplug now.
