want to get a dump valve that gives a nice whoosh. what would you recomend
i have heard recirculating ones are good??
dump valve
- whitegtipolo
stay fully recirc i know from trying everything from full blow off to the splitter forge valve which is poo!(you will get running problems) Get the forge fully recirc one, a cone filter and remove your sound deadening under your bonnet! Then it will be loud , makes it louder after a remap and forge turbo intaken pipe! Hope this helps!
yeah really helpful, do you still get the whoosh with the full recircwhitegtipolo wrote:stay fully recirc i know from trying everything from full blow off to the splitter forge valve which is poo!(you will get running problems) Get the forge fully recirc one, a cone filter and remove your sound deadening under your bonnet! Then it will be loud , makes it louder after a remap and forge turbo intaken pipe! Hope this helps!
- whitegtipolo
