Window switch gremlins
v_dubster
Post by v_dubster »
The window switches in the driver's door have just decided to operate the opposite windows to usual :shock:
Any ideas why this might happen? :?
stig247
Post by stig247 »
rain usually sends my swithches banana's
chewy
Post by chewy »
mine did this once, I turned the eigine off waited 30 seconds or so then started it up again and it was fine. touch wood lol
panda
Post by panda »
I had exactly the same as chewy and used exactly the same fix!
I had a problem with my wipers once - I got them switched on (auto) but could not stop them or change speed. When I eventually stopped at lights I did an engine off and on - problem solved. Remember most of these tasks are now carried out indirectly by a controller - not as in the past by direct wiring - so something is just getting confused - just usual electronics problems (remember that when you next get on a plane!).
v_dubster
Post by v_dubster »
Cheers guys, sure enough they magically swapped back after a while :lol:
