Fog and Side Repeater
Anyone know how to get in to change the the front fog and the side repeater bulbs, both have gone on the o/s. Cheers
The front foglight bulbs - I think that they are easiest reached from below after removing the lower engine cover. The side repeater bulbs - the lamp assembly is retained by one end having a vee in the plastic and a steel spring at the other end, the way to remove it is to slide the assembly back or forwards against the spring then ease out the "vee'd" end. The thing is how to feel which is the spring end - then you are home and dry. Other way if you can't get this method to work is to remove the wheel arch liner and remove the lamp fitting from the rear of the lamp assembly - maybe buy a Haynes book as they are quite handy to have.
