Leaky Passenger door Please Help!!!
pologti76
Post by pologti76 »
i got into my car the other day after it had chucked it down and my passenger mat was wet i thought that i had left the window slightly open but it was shut i have also taken the door card off and sealed all round the foam incase the water was getting in there and i also checked the door seal was pushed down properly but it rained again yesterday and my mat is wet again. any ideas
Sounds like the drain near the cabin filter is. Its under the covering on the passenger side of the windscreen.
If you have the bonnet open, its on the right. Remove this cover and clear out any old leaves and rubbish in there, and hopefully it will stop :)
pologti76
Post by pologti76 »
cheers alex ill have a look thanks
layton
Tim_GTi
Post Whore
Post by Tim_GTi »
If that doesnt solve it, have you had a power cable run for any sort of ICE? If so, where did you run it into the bay?
