Topic links
Topic links
How do I put a link into a topic from another topic on the forum?
Well, there are two ways.
First method: when you want to put a link in, just copy and paste the address from the address bar in your browser, in to your topic. For example, for the Forum Index you would copy and paste the link http://www.tigerstyle.co.uk/poloforum/index.php
The forum automatically sorts out the URL code for you as it recognises a valid web address.
Second method: you might want to put a link in that, instead of showing the whole address, shows a word of text like "link" or "clicky". To do this, try the following code:
forum index
Remove the "quote" marks in the text above to get this result: forum index
Hope this helps!
Si
forum index
Hope this helps!
Si
