hi,
i have a polo 2006 been trying to find the plugs for it and the gap clearance. the vin is W V W ZZZ9NZ6Y129338 ... i also seem to have a faulty oxygen sensor.. where would be the cheapest place to get one and roughly how much...
thanks in advance
spark plug & oxygen sensor???
Just take a plug out and read the model number off the circular section at the base - it will probably be an NGK plug but should have a VW logo on it if its still the set fitted at the factory. Might be best to buy your lambda probe at VAG as if you buy elsewhere you will need to splice in the original connector (I think).
