Help! - Air Box / Hose - Strange Noise / Vibration
one_must_fall
Post by one_must_fall »
The Polo is currently making a odd noise when the car revs at about 2000rpm.
I've taken it to the garage and the hose leading to the air box has been identified as the culprit. Unfortunately this part is no longer available from VW so I've had to use some cable ties and a jubilee clip to try and fix the vibration, but its not worked.
I was wondering if anyone else has had this problem, and what solutions they may have used. I'm not really prepared to replace it with some tubing from eBay...
Photos / diagrams would be fantastic.
Cheers,
Chris
chrischap2003
Post by chrischap2003 »
I have an odd noise when at steady 2000rpm also.... doesnt bother me much, but it would be nice to know what it is lol...mine Sounds like a grasshopper
shantybeater
Post by shantybeater »
^^ i used to have exactly the same noise on mine at around 2k...never worked out what it was....exactly like a grasshopper, kind of rattly metallic sound...weird
I ended up just thinking it was the exhaust vibrating at a certain pitch
mattupson
Post by mattupson »
I have this rattely/mettalic sound, only around a certain RPM/Speed though.
chrischap2003
I thought it was only mine lol...Sounds like we've touched on a new common problem lol...if anyone finds out what the fix is throw it up in here :-)
I actually took a short video, ill upload it now to see if its the same
one_must_fall
I had the garage check the exhaust out, there's nothing obviously wrong with it.
Its definitely the air box hose because you can stop the noise by holding it a certain way...
mattupson
Post by mattupson »
chrischap2003 wrote:I thought it was only mine lol...Sounds like we've touched on a new common problem lol...if anyone finds out what the fix is throw it up in here :-)
It's very strange, almost sounds liek it's coming from behind the dash in my car :S
chrischap2003
It turns out when i uploaded the video i couldnt hear it...lol
Ive also noticed its at its loudest whilst i am sat in the car, if i open my door it cant be heard...hmnmmm
Anyone figured this out yet?
tegwin
Post by tegwin »
Does it sound like its comming from the left hand side of the car when u are driving along?...
Mine has started doing it as well....WTF is going on with this :S :p
Kelk11
Post by Kelk11 »
mine does the same its definately from the drivers side. when im coasting at around 2000 rpm there is a tinkering noise. obviously nothing to worry about if everyone is experiencing it.
Si_GTi
Moderator
Post by Si_GTi »
I have the same symptoms as tegwin. Started not long after I fitted the BMC, have not yet found the cause, two years after it started!! Have changed the air feed hosing twice in this time and had the kit off and on again!
tegwin
Post by tegwin »
My car is standard....im not convinced its anything to do with the engine intake...
I was wondering if it was a loose pannel somewhere under the car.....I need to investigate...but it takes time...which I dont have!
chrischap2003
I was thinking it may be a loose something under the car...it certainly does sound like its coming from just behind the dash mind :-s lol
marcgoldhawk
Re: Help! - Air Box / Hose - Strange Noise / Vibration
Post by marcgoldhawk »
Anyone figure what the vibrating noise actually was??? Have the same problem, but only after driving my car hard,,,
6N2 GTI 00
Post by 6N2 GTI 00 »
Original airbox is a hard item to source these days, it might be worth switching to a BMC CDA Carbon airbox because they sound very nice and don't rattle at all.
