idling problem
Razz
idling problem
Post by Razz »
was in traffic today and i put my pedal down n went up to about 2500 revs and let go of accelerator as traffic didnt move and instead of the car idling at just below 1000 it stayed at roughly 1500 revs and wouldnt go down
any ideas what the problem may be? after a while it went down, but it kept doing this.. as i went above 1500 mark it would come down to around 1400 n stay there for a few secs and then go down to just below 1000 where it should be
throttle body needs cleaning?
Tim_GTi
Post Whore
Post by Tim_GTi »
Have you cleaned the TB? It sounds possibly more than that, but it's always a good start.
Razz
Post by Razz »
nah i havnt done anything yet, what can also be related?
Tim_GTi
Post Whore
Post by Tim_GTi »
Not sure myself. give it a clean though and see how it feels. Regardless of if it's fixes it or not, it'll drive alot better!
Razz
Post by Razz »
since i have no idea about anything.. will my local garage be able to clean it out for me?
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh but there's absolutely no need, it's dead easy mate. Can you locate the airbox on your car? take that off and it exposes the throttle body,
This is what it looks like, dirty and clean:
To clean it, get hold of some 'carb cleaner', it's sold in halfords. Spray it onto a cloth and clean the TB and butterfly valve. then start up the car, and get some to pump the accelerator, up to about 70k and down again, constantly (you'll see the valve opening). Whilst they are doing this, spray around a third of the can into the TB. When finished leave the car running, and take it for a good drive after.
Wynns Carb and Fuel Intake Cleaner - Purple capped can :)
Trottagti
Post by Trottagti »
I have only wipped my round with cleaner, wd40!
Not sprayed it into the carb wen running as i fort that is a very bad thing to do, sure its ok to spray that much into the carb???
you can spray the wynns stuff into the throttle body. Its mainly petrol and xylene based which is combustible anyway plus it is designed to be sprayed in as it will clean all the insides out
Trottagti
Post by Trottagti »
Ah writ ok then i was just abit concerned as to sprayin it all in and i gotta rev it on and off to clean it properly yeah??
Tim_GTi
Post Whore
Post by Tim_GTi »
Trottagti wrote:Ah writ ok then i was just abit concerned as to sprayin it all in and i gotta rev it on and off to clean it properly yeah??
Rev it up and down to open up the butterfly so you can spray inside. When finished spraying and leaving the car running, take it for a good run after.
Trottagti
Post by Trottagti »
Yeah il get some from work i rekon! cheers dude!
one_must_fall
Post by one_must_fall »
It could be the classic coolant temp sensor problem?
That does sound suspect. Cant hurt to change it!
1der
Post by 1der »
has anybody got a pic showing the location of the coolant temp sensor?
