Hi all,
I was just wondering if it's possible to get some new pre-configured brake pipes or would I need to bend my own ones with someone who has a flaring tool?
Replacement brake pipes
Hi mate, im afraid you will have to bend your own because you can't buy them pre-bent! When i did mine i bought a 10m roll of cunifer brake piping, measured the old ones with the aid of a piece of string, cut the piping to length and making sure the ends are filed square and burr free (this gives a better flare). Take them to your local motorcount (or equivelent) to have the end 'nipples' put on and the ends flared, it doesn't cost much at all just takes a bit of time and effort
Polo is mot'd, now. The tester starred very long at them when re-testing, though.
The coating of those pipes has a few punctures where it starts rusting. I simply cleaned those spots with sandpaper and gave it a finish with WD-40 and an oily working glove.
Does someone know a proper treatment for the perforated coating that prevents the pipe from further rusting?
