I recently had my cam belt and water pump changed by a local garage (parts from GSF). Since I got the car back I've been consistently getting lower MPG - almost up to 20% lower (mid 40s on the commute). Also, the power delivery has altered - there is less of a surge up to 3k rpm (only a little less) and much more of a noticable surge post 3k rpm - it will spin the wheels in 2nd on a damp road at this point.
Are the cam belt and resulting behaviour a coincidence? I would think if the belt was a tooth out it wouldn't run at all well.
Is there anything that needs to be done during a cam belt change that might have been missed?
Cheers for any advice.
mpg and power delivery have changed for the worst
david burton
K.I.T.T.
- Drives: Bicycle
Re: mpg and power delivery have changed for the worst
Lower MPG could be due to a timing issue...also, your car is remapped if memory serves well? If the timing was off mechanically, a remap could complicate matters further as far as power delivery goes. I'd check the timing first of all...
Hope you manage to sort it out as soon as possible
Ash
Ash
david burton
I thought it was only right to post an update on this - it's been an age....
The issue took a while to diagnose, but Storm Developments found the problem in the end.
I took it back to the guy and he checked the whole lot with my help, but nothing showed up. Then when I took it to Storm they also struggled until they delved in further (an hour's labour got nowhere).
The issue was the belt wasn't tensioned properly. This led to a "variable" timing that differed under load and so on as the belt tried to catch up tension-wise. They redid the belt and it's back to normal now. When the engine was static it all looked OK.
So, £200 lighter and all is well. Told the original garage but I didn't want to press the matter because it's a mate.
