I also have a slicone reducer which I bought from Silicone Hoses, so its one of the best you can get. 70mm - 60mm ID, 80mm - 70mm OD reducer. Its brand new as I decided on running my BMC slightly different to how I planned.
Also avaliable are some hose clamps which I also bought from Silicone Hoses which are also no longer needed due to my change of plans. All are new and one is still in its bag. Two larger ones are 60-80mm, middle one is 50-70mm. Then the smallest one is 17-25mm. If you check out their website it gives you details of why these are the ones to choose.
Lastly I have some rubber hoses spare and clamps. The rubber hoses are 19mm-20mm wide and range from 50mm to 80mm. The clear pipe is 5-6mm and 220mm long. I also have 9 16-29mm clamps. These are not as good quality as above but still do the job!
Any questions just PM or reply. Cheers.
