throttle body size???
Hi, just a quick one, what size 90degree bend would i need, i think its a 70mm inside diameter? cheers
- Tim_GTi
- Post Whore
Re: throttle body size???
Throttle body size is 63mm
ah right so i need 63mm i.d. pipe work, cheers
- Tim_GTi
- Post Whore
Ideally yeh, 64mm will fit though, apparently this can be bought on eBay. I would imagine you'd be able to go up to close of 70mm. Just make sure you secure it tightly with a jubilee clip.
nice one, cheers for the help
The bend that holds my CDA is 60mm to the throttle body, it fits, but its a tight fit!
Cheapest place for a 90º bend?
Im knocking up a cheap K&N kit from bits from my old Renault.
- Tim_GTi
- Post Whore
I would say eBay mateTigz wrote:Cheapest place for a 90º bend?
