can some one help
callum aspinall
can some one help
Post by callum aspinall »
i just wanted to ask if the standard polo gti is lower then the 1.2 and if it is would the suspension fit a 1.2 as i want to lower my 1.2 slightly but dont want it to loose any comfort as its a family car
Re: can some one help
Yes the GTI will sit lower than the 1.2, but it would not be the correct thing to do to fit the GTI suspension as the axle weights of both cars are not the same. I'm sure that you can get sports suspension for your car - even check the accessory list for your Polo - but I'm sure that there will be cheaper options that still allow you to achieve what you want without ending up with the car getting droppd too low for your use.
chewy
Post by chewy »
The gti is only 15mm lower iirc
30mm Eibach springs cant fault them
http://www.venommotorsport.com//product ... Suspension
